Threads: 6
Thanks Received: 2 in 2 posts
Anybody replaced/removed their original airbox/filters etc with a K&N air filter on a 1.9d?
My airbox is very rickety and literally held together with cable ties to stop it rocking about. This got me thinking could it just be removed and replaced with a K&N positioned near to the grill? Are there any sensors or wiring that I need to take into consideration?
I know its not going to make any crazy performance gains!!! But the current air filter housing hangs down very low on my van (lower than the sump) and I would like to eliminate this
Any advise or help would be greatly appreciated.
2001 1.9D 800 160000
The following 1 user says Thank You to wellsy for this post:1 user says Thank You to wellsy for this post
• G.mk3
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Can't see why not,engine will breath better,I was thinking the same
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
"My airbox is very rickety and literally held together with cable ties to stop it rocking about. This got me thinking could it just be removed and replaced with a K&N positioned near to the grill? Are there any sensors or wiring that I need to take into consideration?"
I know what you mean as I`ve a similar problem . The only thing is the air mass sensor on the air filter box outlet.
Threads: 67
Thanks Given: 237
50
With a 1.9 all you'll gain is more noise ......
Serieal Berlingo owner
Threads: 67
Thanks Given: 237
50
25-11-2016, 09:17 AM
(This post was last modified: 25-11-2016, 09:20 AM by geoff.)
^^^ Yes power loss is a distinct possibility !!
A few years back I fitted LPG to a Series Land Rover and initially for test purposes I had a " lash up pipe " leading from the air box to the carb mixer and the engine ran really well ..... later on I replaced the pipe with a cosmetically improved same diameter pipe but the outcome was unexpected ... the engine ran poorly and had a lot less power.
Each pipe was internally ribbed and of differing lengths otherwise exactly the same.
So began a series of tests to find the best combination of pipe type and length and after much fettling and scribbling down of test results I found the optimum. Having Megajolt ignition allowed me to plug in a laptop for live monitoring as I drove around my test circuit / local hills and analyse the data.
So all of the above work just for changing pipe type and length !!! At least if you do swap to K&N it is easily reversible and the filter can be sold on to recoup some of the outlay, personally I'd go to a scrappy and get more of the same in better condition, just my experiences.
Threads: 29
Thanks Given: 67
20
(25-11-2016, 09:17 AM)geoff Wrote: ^^^ Yes power loss is a distinct possibility !!
But it's a 1.9, will you notice a bit less power
