New battery but won't start
Hi.
I changed my battery as the old one sucked in cold weather. I went to turn it on and it turned over but didn't start. I could also hear ticking noises coming from the engine fuse box but now that has stopped too. Any suggestions would be great thanks.
Adam
Forgot to mention the van has already started and been driven around.
Did u do the 3 minute rule before changing battery?
(25-11-2016, 07:02 PM)Johny555 Wrote:  Did u do the 3 minute rule before changing battery?
It was at least 5 mins before I reconnected it
The main suspect is the starting motor has seen better day's Sad but check all the wiring first to make sure you haven't got a bad connection earth or live .
(25-11-2016, 04:26 PM)Adam Shears Wrote:   I went to turn it on and it ticked over but didn't start.
 Does the starter spin the engine over at a good fast speed - in a normal way that is ?  Not familiar with the ticking over aspect ???
(25-11-2016, 08:42 PM)Jed Clampit Wrote:  The main suspect is the starting motor has seen better day's Sad but check all the wiring first to make sure you haven't got a bad connection earth or live .
All the lights come on on the dash but the glow plug heater light does not even flash when I first turn the key
Can you described when it ticks/clicks? Is it when you turn the ignition? Also does the engines turnover or just clicking ? First thing to check is earth wire and then rest off terminals are tight as sometimes they can vibrate loose.
Sorry I meant turned over which is does very well
Have the glow plugs been changed at all!! My brothers did the same on his mk1. Couldn't change all the glow plugs as one was seized solid so just did 3 of them. Bloody pain but it is an R plate with 168k on it
I'm not sure but the orange engine light has been on for 6 months or so. Will try the glow plugs tomorrow. The thing is it started first every time before I changed the battery apart from when it was flat.
Last Post: BigVtwin996
Yesterday 12:10 PM
Eolys replacement tank
Last Post: jw4821
Yesterday 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
