Threads: 5
Thanks Received: 1 in 1 posts
Evening all, I have a 2.0 hdi. Oil change its getting close, just wondering what's people thoughts would be on using john Deere plus 50 oil it's 15w 40?
Thanks Michael
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
25-11-2016, 08:17 PM
(This post was last modified: 25-11-2016, 08:19 PM by jj9.)
15w-40 is a bit thick when cold and is not one of the grades recommended for the 2.0 HDI, so even if you can get it for free it's a bit of a risk especially in the winter months up north.
10w-40 is listed as being a grade suitable for the 2.0 HDI but personally I would rather use 5w-40.
You don't need to buy top notch expensive oil if changing it frequently (6-7k) a 5w-40 semi synthetic will be fine....well it has been in all of my turbo diesel vehicles.
Threads: 5
Thanks guys much appreciated
Threads: 34
Thanks Received: 21 in 20 posts
Thanks Given: 23
26-11-2016, 09:06 AM
(This post was last modified: 26-11-2016, 09:06 AM by ghost123uk.)
I just recently put 5/40 Fully Synthetic in mine. I hope I've done the right thing as that link that Solent provided ^^^ seems to point to 10/40 Semi Synth.
btw Michael, have you read the stuff about the importance of draining the old stuff correctly? (though more important on the 1.6, apparently)
Threads: 8
Thanks Given: 305
35
26-11-2016, 10:19 AM
(This post was last modified: 26-11-2016, 10:20 AM by jj9.)
(26-11-2016, 09:58 AM)polar Wrote: That site seems to advise on the lowest spec for an engine it suggests my 1.6hdi is 5w40 when that spec was changed by Citroen years ago to 5w30 low SAPS.
Was the spec not changed by Citroen when the engine was fitted with a Diesel Particulate Filter (DPF) so 5w-40 would be fine if you had a 1.6 hdi with no DPF.
Threads: 123
Thanks Given: 250
34
The JD 15w40 will be a bit too er dare I say agricultural :-) It may well not protect your engine on cold starts and will be harder to start. Also it may be Dino Multigrade oil, if so best for the mower when compared to modern oils.
From what I read in the Citroen documents, you can use 10w40 semi synth as a minimum or 0/5w40 fully synth. I put 5w40 in my 2.0HDi and will probably do the same again in a few months after winter.
I have no shares in ECP or CP4l, but thought that I'd mention they have 50% off on oils this weekend a very good deal for 10w40 Semi, or CP4L may be slightly better for 5w40.
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
I put 5w40fully sin in mine.thats what I was told to use.2 Lt hdi.
