Threads: 2
Hi my heater blower has stopped completely, no problems before. I have no fuse box layout.
Anybody got one and know if there is a separate fuse other than the resistors on the blower?
Threads: 73
Thanks Received: 44 in 33 posts
Hi. had the same problem. i had to change the heater control unit in the dash.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
Could be a fuse (it's under the psf1 in the engine bay, there's a row of maxi fuses hidden and there's one that's the heater blower, more common is the heater resistor, short out the two biggest leads and see if the blower blows... if it does get a new resistor but you may or may not also need a new motor as generally excess current blows the resistor....
