Threads: 6
Thanks Given: 2
I've got the plate but just out of curiosity I wanted to use the egr spray cleaner and take it up the motorway for few hundred miles to see if there was any difference, it's having a service in December and my mechanic is going blank my EGR with the plate I bought off Ebay.
Did you not clean your EGR? And just blank it straight off?
Sent from my SM-N910F using Tapatalk
Using Tapatalk
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
I think if you give it plenty of long runs on motorways the valve will b ok.diesel engines need a good run.
Threads: 6
Thanks Given: 2
Hi Guys, I took it for a long run up to Birmingham from wales had a full service done by a garage i trust and he eventually changed the EGR for a new one as it was too badly damaged, also i however need a new seal on injector number 3 and he wants to check my turbo as its not kicking in and thinks its possibly the vanes and turbine itself caked in crud the same as what he cleaned from my engine manifold.
Using Tapatalk
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
For anyone reading this it's not physically possible to spray something in an intake and have it clean the egr valve, anything you spray in might de crud the intake manifold to some extent, but it will never get near an egr valve itself!! It's snake oil in a tin!!
Threads: 6
Thanks Given: 2
I ended up.having the manifold cleaned and a new valve guys... but found I now need new turbo vanes and a seal for number 3 injector
Using Tapatalk
Threads: 23
Thanks Given: 50
29
Your right it mite get there after its be burnt with the diesel and put through the EGR back into the inlet manifold but what good will that be .
