Drivers door locking problem
Hello I am having a problem with my drivers door lock, the key don't always open it, sometimes it will and sometimes it won't, for speed I find I have to now unlock the passenger door then pull up the drivers door lock to get in the van.
When drivers door does work the whole van locks open or close.
The center button for central locking works fine for all doors.
the key fob is broken no buttons so can't use that.
passenger door and boot can be manually open/shut with a different key then the drivers door lock.
Any advice?
Sounds like the driver's side lock is faulty or worn, or maybe the key is also worn? Can you get a new key fob and swap the insides?
(28-11-2016, 08:42 AM)cancunia Wrote:  Sounds like the driver's side lock is faulty or worn, or maybe the key is also worn? Can you get a new key fob and swap the insides?
Above + possible wires broken in the door loom at the hinges.
(27-11-2016, 11:56 PM)Nemie Wrote:  the key fob is broken no buttons so can't use that.
You can quite easily and very cheaply (via ebay) get a new fob and fit you existing metal key into it. I recently did mine. I had to epoxy glue the metal part of the key into the new fob, but that was easy enough. Also NOTE WELL, there is a tiny transponder inside the fob, as well as the little circuit board. I didn't know this and had to route around in the bin to get my old fob back to swap this tiny "thingy" to the new fob. All good now Smile Cool
I know this ^^^ is not the answer to your door lock problem, but it might be summat you didn't know.
I will look into all the above thanks for the replys will post back when fixed.
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
