Rear Wiper Motor
Hi Folks,
The rear wiper on my Pug Partner Combi has stopped working. The large gear inside has stripped some teeth in a certain area.
Is there another more common Peugeot or Citroen like 206/306/Xsara hatch etc that use the same wiper motor?
Mine has a lift up tailgate, and not separate doors.
Thanks in advance Rolleyes
Will
P.s, it's a 2001/51 plate.
Good question- I know the rear wiper motor gears are notorious for failing. Mine had failed when I bought it but I was lucky enough to find one in a scrappy to replace it with.
I can't see Citroen/Peugeot developing an entire new motor for the Berlingo? I should imagine the motor itself might be a common fit with other Citroen/Pug models but the mounting plate it's on is probably Berlingo-specific. Best bet would be take motor off, go to a scrappy and see if you can find a similar-looking motor that might mount on to the plate from the Berlingo?
(07-12-2016, 08:48 PM)minisandfords Wrote:  Good question- I know the rear wiper motor gears are notorious for failing.  Mine had failed when I bought it but I was lucky enough to find one in a scrappy to replace it with.
Cheers for the reply minisandfords.
Yeh, I think a scrappy run is what's needed.
I was hoping that someone on here might know what other models share the same internals. If the mounting is different, but the internals are the same, I can strip the bits from one and fit into mine to get it working again.
Will
Will
if its anything like pug 306 window motors theres probably half a dozen different non interchangable ones on your model alone .... best of luck
Yesterday 04:24 PM
» Replies: 35
Last Post: Vlad
Yesterday 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
09-06-2025 06:25 AM
» Replies: 34
Sump, Any good swear words?
04-06-2025 12:34 PM
6 speed gearbox conversion
Last Post: xtrmark
03-06-2025 05:29 AM
» Replies: 39
Part of Dipstick Stuck
01-06-2025 10:43 AM
