B9 DPF Tank Top-Up
I have just done my first DPF fluid (Eolys) reservoir top-up today, and it was a fairly straightforward job, but I thought I would write this to help others on here, who may be thinking of having a go.
I own a 2015 B9 1.6 HDi L2 van, and the low DPF warning started displaying on the centre console at 115,850 miles. The message simply said “Engine fault”, “Risk of filter clogging” i.e. the Particulate Filter.
I already had the fluid top-up kit, which I had bought when my van had only done 75,000 miles. The Kit cost £130 from a Citroen dealer, and includes 3L of the fluid, but I found out today that my Eolys tank only holds 2L. This liquid is supposed to be pretty toxic stuff, so always wear gloves and eye protection while working with it.
I reversed my van up on to car ramps and simultaneously raised the front wheels onto thick planks of wood as I went backwards. This gave me more than enough space to crawl under the van, and access the reservoir, which is just in front of the offside rear wheel (Drivers side). It is hidden behind a plastic cover held on with 3 x 10mm bolts. As ever, it’s a good idea to disconnect the vehicle battery at this point.
You have to remove the whole plastic Eolys fluid tank to top it up (it’s easier anyway), It is simply held in position by one 13mm nut on a long captive bolt on one corner (you may need a 13mm box spanner to access it), and 2 re-useable white plastic rivets which attach the tank to the exhaust pipe heat shield. You then have to move the tank diagonally from the left rear towards the front right to disengage lugs on the top of the tank which locate on 2 large fixed “buttons” on the underside of the van. This enables you to drop the Eolys tank down enough to disengage an electrical connection and the fluid pump outlet pipe.
With the tank out and placed upright and level, disconnect the “U” shaped flexible pipe on top of the tank and connect the pipe stub of the new fluid filler bottle connector to this flexible pipe. Then connect an “overflow” pipe to the plastic pipe stub on the tank which the U shaped pipe had formerly been connected to, and feed this overflow pipe into an empty plastic bottle, to catch any surplus from the filling operation.
Proceed to fill the tank with new fluid until it starts to come out of the overflow. This will be after you have put in about 2L in.
Re-assembly is simply the reverse of the above. You will have to have the DPF fluid counter reset in the ECU to cancel the dashboard error messages. You can either pay a Citroen dealer £60 to do this, or find someone on here with the requisite laptop and software, who will do it for a lot less!
[-] The following 5 users say Thank You to CourierJim for this post:
  • Hardnut, Opensauce, osborneelectric, Satellitemark, Zen_Speedmaster
Cheers for writing all that out. Do current engines still use Eolys as well as AdBlue?
(01-12-2016, 08:13 PM)Opensauce Wrote:  Cheers for writing all that out. Do current engines still use Eolys as well as AdBlue?
No.AdBlue is the new version & is a lot easier & cheaper to fill.The filler is next to the fuel filler. Big Grin
  • Opensauce
@CourierJim
I did exactly the same job myself not so long ago. The only thing that I found weird though, was the fact that although the tank could take more than 1L (I poured 1.5L into mine more or less) , the BSI counter only showed a 1000 mL (1L) capacity. And this value could not be changed, only reset...Was it the same in your case?
(02-12-2016, 06:22 AM)Luis Rosa Wrote:  @CourierJim
I don't have any plug-in Lexia software so don't know to what you are referring. I would just like to take this opportunity to thank Forum member "Lighty" who reset my ECU DPF counter this morning with his laptop for a very reasonable price.
Pleasure to be a help Jim, have to say, your van is a credit to you & looks like new ?
The plastic rivets , how do they come apart ?
I've been through this loop - there does seem to be Adblue and the DAP additive in the Cat6 Berlingos. I am quite happy to be corrected on this! Garage in Edinburgh tells me it needs sorting at 10k miles.
(31-07-2020, 01:42 PM)Maximan Wrote:  I've been through this loop - there does seem to be Adblue and the DAP additive in the Cat6 Berlingos. I am quite happy to be corrected on this! Garage in Edinburgh tells me it needs sorting at 10k miles.
It's true for some reason no one seems to know about it. Please don't say this is an old thread as it will only just becoming relevant as people get to 100k
Just to add to this thread incase anyone else receives the 'P filter fluid level low' message.
I've got a mk2 berlingo xtr 11plate.
After speaking to my trusted auto diagnostician, I was advised that all I needed to do was buy eloys fluid and top up the tank. He kindly reset the error code for me and I ordered The litre of the fluid from ebay for about £25 with filling tubes.(error reset was free... As we're family)
If my hands were smaller I could have filled without any hassle, unclip the tube, easy as that.
To give myself a bit more room I jacked up the rear, removed rear wheel. Unclipped tube from the dpf tank and let 1L of the fluid drain in. Popped fitting back on, wheel back on, lowered Jack and Bob's your uncle.
Granted it was a bit fiddly to unclip, but I needed only press one side button and it came off. The tank holds 1.7ish litres so will top up again in 50-70k (it was 110k before error) I could have bought an extra litre to fill it properly but what's the point, it was an easy job.
Will also add that tank sounded empty... and could hear new fluid draining/dripping in. Now it sloshes.
engine light
Yesterday 01:00 PM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
