2.0 HDi fuel issues as per **update
Hi all wondering if any one has any input on my issues,
I have a 2001 HDi berlingo, bought it with EML on giving P0230. It ran fine no issues at 1st, it conked out on motorway with me after a few days with quater a tank showing but turns out after a gallon of fuel thrown in she came to life and for a couple days it ran on and off limp mode restricting power and now and then it would cut out randomly, when eml on you can turn off and take key out it would continue to run for a second or two.
Now i replaced the fuel filter and filled the tank it ran spot on no lights and no issues, until yesterday i drove home and then it wouldnt start again, the lift pump is not coming on with ignition but i can here a relay clicking some were when ignition is turned on, just no fuel pump, no fuel reaching the filter either. Its deffo the lift pump not coming on and the "stop" light is on dash. Is there any thing to check before i go for lift pump as its a tank out job and not something i look forward to as vans parked on a main road
Fuses and Relay first, then wiring and finally pump
Col can you direct me to the relay, i was told behind battery but there is ecu and behind it is a black box with lives going in. As for the fuse i have tried to make sense of the fuse box and find a guid as to what fuse goes were but no joy the index i could find on google had no fuse in the 1 described as fuel pump?
there is a fuse in the engine fuse box F25 according to my h/book.
According to Haynes there is only a lift pump if you have a Bosch system.
I was searching for a switch for my Berlingo when I came across this about a relay in the fuse box.
" VARIOUS APPLICATIONS
COMMONLY CONTROLS AIR CONDITIONING AND MORE IMPORTANTLY THE FUEL PUMP DELIVERY. FAILURE CAN OCCUR RENDERING THE VEHICLE IMMOBILE. THE CAR WILL TURN OVER BUT NOT FIRE.
TRY SWAPPING THE AIR CON RELAY WITH THE FUEL PUMP CONTROL RELAY. IF SHE FIRES, YOU'VE CRACKED IT. "
It would be worth trying IF you have air con., would rule out a dodgy relay
Hi no it doesnt have air conditioning, and yes im sure its bosch R65 pump being the 90bhp model and all fuses in engine compartment are intact. Thanks for replies. Its pointing more and more to lift pump but i know what hdi is like and too many sensors everywere one of them could be preventing the pump from lifting, without dropping tank i need a way to check the suply to that pump and see if power is being sent from the front to the back because if not, then no point to drop tank. On one attempt to try start it yesterday i got a yellow key warning light and a beep, but quick flash and not been back on again. Tried a bsi reset to no avail as no central locking maybe it has no effect
So now i have an update!
Taken tank out, ran a direct live and earth to the pump and nothing.... so new pump in, rigged back up.. filled with fuel and hey presto it runs! So i head out after clearing the codes and its off like a bullet. Eml comes on it drops into limp mode (2krpm) and when you let off accelerator it cuts out wether in gear or not, u have to take the key out, and back in to restart it.. even if you clear the codes, instantly back in limp mode and will cut out when you let off
Did you check fuel pressure sensor ?
On the side of the HP pump.
It is common problem for 2.0 hdi.
You can take it off and clean. Carb cleaner.
Replace orings.
If it helps then you need to buy new one.
Best regards,
brajomobil
This may be of interest:
https://www.pug306.net/forum/archive/ind...41654.html
Thanks, i will go take the fpr out now and clean it up. See if this works. Will update later today
Mileage
Last Post: Taffy747
Yesterday 11:51 AM
Yesterday 09:17 AM
Yet another ABS fault
10-05-2026 10:13 PM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
