lubricating door
What type of lubrication is recommended  for door hinges, slider roller, locks ?
(04-12-2016, 08:57 AM)sks01773 Wrote:  What type of lubrication is recommended  for door hinges, slider roller, locks ?
I normally use a light lubricant like WD40 though its disadvantage is that it quickly disappears and has to be done regularly. You would do well to stay away from grease for the locks as they tend to retain a lot dust leading to seizure of the lock.
[-] The following 1 user says Thank You to Civvic for this post:
  • sks01773
LIDL -> w5 silicone spray.
It lasts for 3 months.
Best regards,
brajomobil
[-] The following 1 user says Thank You to brajomobil for this post:
  • sks01773
is wd40 white lithium grease ok ?
(05-12-2016, 10:52 AM)sks01773 Wrote:  is wd40 white lithium grease ok ?
It should be fine, but may attract dust & dirt as mentioned above. Mine have ordinary grease on the runners and catches which was put on by the person I bought the car from. Not had any problems yet, but only 2 months usage so not sure about the long term.
  • sks01773
Silicone grease won't dry out
  • sks01773
I use motorcycle chain lube for hinges & rollers etc.Don't use WD40 in lock as it dries out.
  • sks01773
+1 for silicone aerosol. Doesn't attract / hold onto muck and doesn't dry out. I use one called GT85.
[-] The following 1 user says Thank You to ghost123uk for this post:
  • sks01773
Last Post: andy@andymcm.com
Yesterday 01:47 PM
» Replies: 24
ASDA AdBlue 10 January 2026
Yesterday 09:06 AM
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
