Threads: 4
Thanks Received: 7 in 2 posts
Thanks Given: 15
I bought a 2003 1.9D Multispace a couple of weeks ago.
The seller said it would do 60mpg - yeah, right...sat on the back of a low-loader perhaps.
Just done a 200 mile consumption check - just under 26 litres.
35 miles to the gallon!
To be fair with it being new I've pushed it to see what its top-end mph is (twice) and a couple of trips have been around town carrying plywood sheets and DJ equipment to a gig. We had a bit of a drag race with a Range Rover once over 1/4 mile and been stuck in crawling traffic a couple of times.
But really? 35mpg on a diesel?? I thought these things were cheap to run???
Threads: 20
Thanks Given: 2,126
18
When was it last serviced? When i used to buy S/h vehicles I gave them a major service on the,often correct assumption,that they were way overdue.I can't speak on the 1.9 Berlingo but would expect 45-50 mpg used reasonably.My old 1.8 C15 did 55mpg but that was a lighter vehicle.What mileage is yours?
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• AlanDeejay
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
With heavy foot,thrashing it will use more diesel,my old combo was great round town on fuel but on motorway mid 30s to a gallon,
Threads: 15
Thanks Given: 46
5
I had a 1.9D & it averaged about 44mpg at about 65mph motorway cruise. Any faster than that & it would drop down to 40mpg. They are old tech indirect injection so not as economical as hdi diesels. They are quite slow but thrashing it through the gears will just put consumption up. Try your next tankful driving it quite gently & if you can get 45mpg that's as about as good as you will get ime.
Threads: 4
Thanks Given: 15
Thanks for all your replies. Yes, I was thinking 45mpg more the mark.
I'm pretty snowed under with DJing and other work at the moment but I'll service it asap.
Driving economically for the next 200 miles, let's see how we go....
Threads: 2
Thanks Received: 3 in 3 posts
Thanks Given: 12
I keep a good track of fuel economy on my bingo. It's a 2002 1.9D non turbo Multispace and on my regular 48 mile round trip work commute, pulls 45-47 MPG on a mixture of Welsh backroads and A roads.
The following 1 user says Thank You to Wyvern for this post:1 user says Thank You to Wyvern for this post
• AlanDeejay
Threads: 27
Thanks Given: 20
13
My 1.6hdi averages around 56mpg in the summer but it drops to about 52 in the winter. That is with me driving normally, on a decent run it gives a couple of mpg more but if I'm in a hurry it drops considerably.
I don't know why it's worse in winter as I use the A/C quite a bit in summer which I would have thought would drink the fuel.
The following 1 user says Thank You to Solent for this post:1 user says Thank You to Solent for this post
• AlanDeejay
