I'm sure they work to a point. The heater light comes on and goes out after a few seconds. It starts fine on a slightly cold morning, but a real freeze causes problems
All seemed well improved starting how ever after the real chill came back was back to square 1
So today I got down to the clearances all my inlets are closed right up can't even get the 0.04 in there.
Looks like I need to get a timing belt kit/waterpump and find out if the local pug dealer has shims in stock
06 pug partner van dw8 106k miles 04 citroen berlingo forte dw8 125k miles
15 Pug Partner tepee outdoor
16 nissan nv400
87 Land rover ninety pick up
24 52kw pug e-rifter GT line
Fyi mines starts but runs like a filing cabinet falling down stairs until warm and even then it's not smooth.
(I have 2 of these engine so comparing apples with apples my vans loads smoother than the multi space)
16 nissan nv400
The Valve clearance are a common problem on these engine 100,00 mile;s or more so it need's to be one of the first thing to check nice to see your getting it sorted .
It's too orangey for crow's It's just for me and my dog
05-12-2016, 10:12 PM (This post was last modified: 05-12-2016, 10:15 PM by ron.)
(05-12-2016, 06:55 PM)Top drive Wrote: Well I did my glow plugs last week.
If you have a friend in the motor trade,you may be able to 'borrow' a box of used shims.You take what you need & put your shims in to replace what you've used.It's worth asking around.Set all at widest value & a
little too slack is ok but don't take the p. PS A little pressy is in order to thank the donor.
06-12-2016, 06:24 AM (This post was last modified: 06-12-2016, 06:24 AM by Top drive.)
None of my trade mates are into this level of technicality. Their garages are all about the easy money such as timing belts and clutches
They all said swap the engine they are only 50 quid for a low miler.....
Not my style.
16 nissan nv400
