10-12-2016, 07:05 PM
Hi
I'm facing the job of having to change my Siemens diesel fuel pump (part 5WS 40018) and injectors (part 9652173780) as injector number 1 in causing the engine light to come on.
There are some very small pieces of shinny metal in the bottom of the fuel filter housing which I've been told are likely to have come from the failing fuel pump.
Assuming the pump has failed can anyone offer some suggestions on the necessary process for replacing both pump and injectors and then the work necessary to clean out the fuel system to remove further bits of metal that may be circulating? I really don't want to damage the replacement parts by not doing the job properly first time.
