Threads: 3
Thanks Received: 1 in 1 posts
10-12-2016, 07:14 PM
(This post was last modified: 10-12-2016, 07:15 PM by Claydontoby92.)
KEvening all,
Please can someone shed some light on where the wiring goes from the aerial on a 2004 Berlingo.
The van which I purchased recently, is missing the complete aerial & seems to have no wiring either, I was just wondering on the route the wiring takes to get to the radio.
Cheers all
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
If its the same as 2001 berlingo ,the cable from the aerial runs along the top of the windscreen and down behind the cover on the drivers side. The plastic cover comes off easily . That is the only wire to the aerial
The roof light comes out to access the bottom of the aerial (when its there. )
Threads: 123
Thanks Given: 250
34
I'm fairly sure that my '04 Desire / Modutop cable runs down the left (passenger) side but may be wrong. Mine also has a window mounted aerial on the passenger side that works quite well. When I bought the car, there was some black tape where the roof aerial would be, which explains the internal aerial. I bought a cheapo aerial for the roof which was worse reception than the internal, but looks ok.
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Just replaced mine. Shelf above driver has to come out, interior light fitting has to come out. Cable runs along top of windscreen down the passenger side, clipped above the glovebox, which as to come out. Easy enough job.
Malcolm.
2001 1.9D Multispace.
Threads: 3
Thanks guys. Will post An update this week
