Threads: 4
Thanks Received: 7 in 2 posts
Thanks Given: 15
One of my reasons for buying the basic 1.9D engine was that I'm thinking of doing some travelling and I thought if things got a bit tight I could run my Berlingo on filtered waste vegetable oil.
Has anyone tried this? Am I at risk of destroying the engine and injectors or is this just propaganda put about by the petroleum industry?
I've read that Rudolf Diesel ran his early engines on peanut oil and hoped this would be useful in countries where petroleum-based fuels would be difficult to obtain.
However, I imagine the engines have changed a bit since the late 1800's.
Anyone running on chip oil?
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
i Haven't used it but know lots have in a 1.9. oil changes need to be more regular and fuel filter will require changing more frequently.
It can eat away at some rubber fuel lines.
• AlanDeejay
Threads: 12
Thanks Received: 18 in 16 posts
Thanks Given: 14
6
I know some of the Isuzu Trooper lads run on veg oil. The trooper 3.1 can when its warm run full 100% on veg oil. most mix it I think its something like 70/30. the 70 being veg oil.
they all say, carry a gallon of diesel and a spare filter with you. and i think alot of them do 3 tanks veg oil and then 1 tank of straight diesel.
Threads: 123
Thanks Given: 250
34
I read that Lucas / Deplhi pumps are not suitable for veg oil, probably worth checking in a bit more detail.
Threads: 20
Thanks Given: 2,126
18
Before my Berlingos I had a C15 1.8d.I ran it on 25% diesel in summer & 50/50 in winter.I did 50,000 miles on this brew until I sold it @185,000m.In those days veg oil was cheaper than diesel.It gave better mpg & MOT emmisions were lower & ran more smoothly.I had no fuel filter probs at all.I used to put Forte through it every 6 months & reckon it dissolved any thick bits in the f filter.You can't put veg oil in HDi's but you can run them on E20 biodiesel which I use when in Germany.HTH.PS The C15 had Lucas inj system.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• AlanDeejay
Threads: 12
Thanks Given: 14
6
out of interest. how old is the vehicle you are thinking of running this on?
if its an old un and towards the end of its life, you aint got to much to lose running it on veg oil.
Threads: 62
Thanks Received: 715 in 612 posts
Thanks Given: 220
50
Chap I worked with used to run a 1.9D Berlingo on Veg oil, both new and filtered used oil without issue for around 100k miles, he also used to dilute it with used filtered hydraulic oil when it became available in work - 50 gallon drums, also ran on other waste industrial oils too !!! In later days he also made his own bio diesel for the 1.9d ... interesting chap to work with.
I wouldn't suggest using anything other than veg oil
Serieal Berlingo owner
• AlanDeejay
