Reverse parking sensors
Want to fit parking sensors to rear of my 2007 berlingo, have looked on ebay there are some kits that attach the live wire to reverse light power feed.
Has any one fitted such sensors as I am bit wary of the berlingos multiplex wiring.
If you use the forum search you will find some info,   Wink
Just type parking sensors in the search box at the top.
(13-12-2016, 09:10 AM)sks01773 Wrote:  Want to fit parking sensors to rear of my 2007 berlingo, have looked on ebay there are some kits that attach the live wire to reverse light power feed.
You will have to fit a bypass relay.
http://www.towsure.com/fit_a_multiplex_bypass_relay
Malcolm.
2001 1.9D Multispace.
Malcolm.
On mine I fitted a reverse camera. Just solderd it to the reverse light. Works just fine.
Malcolm.
Which year/model?0
I'm going to dispel any rumours! There is no multiplex wiring anywhere near the reverse light! There is a load test performed which tests the bulb and associated wiring but it's not multiplexed in any way! Just tag it in and use the reverse light feed direct, I've never had an issue with any set of reversing sensors I've fitted to any car of any age...
The so called canbus relays are so named as it's card with canbus architecture that generally have bulb checking facility's and so one tends to go hand in hand with the other, again there is no canbus signals or wiring to the back lights at all, hope this helps Smile
[-] The following 1 user says Thank You to dumdum for this post:
  • sks01773
Malcolm.
No he really won't! I love how you say it with such authority, fortunately your wrong on this occasion
Malcolm.
Well you learn something everyday.
My authoritative comment came from personal experience of fitting towbar wiring to my Peugeot 407.  Came with a bypass relay to get a feed from all of the rear lights.
Does this mean the likes of Towsure, PF JOnes etc. are unnecessarily providing bypass relays with their wiring kits for canbus/multiplex vehicles?
Malcolm.
PS. an unnecessarily aggressive post dumdum?
the multiplex towbar relay is just 7 or 8 relays in one package. with some lectronics to sort out the signals on shared wires in the cars loom.   for reverse sensors you would only need a standard single relay to take a signal from the reversing light itself..
(14-12-2016, 12:23 PM)ricc Wrote:  the multiplex towbar relay is just 7 or 8 relays in one package. with some lectronics to sort out the signals on shared wires in the cars loom.    for reverse sensors you would only need a standard single relay to take a signal from the reversing light itself..
Not according to dumdum.  No relay required.
Malcolm.
Last Post: Desdinova
Yesterday 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
