[Engine] Nasty sooty smell
Hi, my 1.9d has a very nasty sooty smell, and also high oil consumption. What could be the issue?
Engine oil leak from the top rocker cover ?, the leaking oil runs down onto the hot exhaust manifold.
  • Civvic
(17-12-2016, 09:27 AM)brodfather11 Wrote:  Engine oil leak from the top rocker cover ?, the leaking oil runs down onto the hot exhaust manifold.
Positive. Had even to change the cover and applied tons of silicon. Negligible leakage but oil consumption still there.
where is the sooty smell ? when you drive it ie the cab , in the engine bay or at the exhaust ?
06 pug partner van dw8 106k miles
04 citroen berlingo forte  dw8 125k miles
15 Pug Partner tepee outdoor
16 nissan nv400
87 Land rover ninety pick up
24 52kw pug e-rifter GT line
(17-12-2016, 12:42 PM)Top drive Wrote:  where is the sooty smell ? when you drive it ie the cab , in the engine bay or at the exhaust ?
Its mostly at the exhaust but it lingers the air after I've entered the driveway without revving hard. The oil turns sooty quite rapidly. i've had the van since 09 and it now has 241,000 Kms on the odo. Has been done one complete rebuild and a couple of gasket changes.
Is the engine running OK and is there a lot of fumes coming out of the engine oil filler cap when running.  ?
If a lot of fumes then it could be your piston rings  Sad
When rebuilt where the valve oil stem seals changed ( another possible cause of oil getting into cylinders.)
Have you had the timing belt done , if wrongly fitted it will run poorly and smokey.
Is the EGR operating properly ?.  Or is it disabled and blocked off.?  Maybe burning/sucking in  more than fumes.
  • Civvic
(18-12-2016, 08:47 AM)brodfather11 Wrote:  Is the engine running OK and is there a lot of fumes coming out of the engine oil filler cap when running.  ?
Engine runs well, just covered 500kms last Friday at the expense of 1 litre of oil. Will check on fumes, but when I open to top up oil I usually see wisps of smoke.
I have been suspecting rings coz of previous overheating incidences before i put in a new radiator.
valve seals were changed during last head work (when I put in brand new head bolts).
Timing should be Ok. It starts and runs fine.
EGR is not not disabled neither blocked off but is not operating well due to engine harness being in a terrible state. For example the EGR switch connector cannot hold due to the catch being broken off, solenoid harness being chapped and insulation worn off (taped), and the Air Flow sensor connector also not mating properly.
I'd like to add, due to the aforementioned issue the EML lights up and the car becomes jerky and weak for short periods -blue smoke manifests, then clears up and continues as normal.
the 1.9 is prone to jerkyness and lacking more so in power when the MAF is not working right.
when i had a buggered MAF the engine wouldnt rev past 4000 - when joining motorway or such like it was like hitting a limiter and jerked badly at around 1800-2000. and EML was on .
What are the stored codes ?
16 nissan nv400
[-] The following 1 user says Thank You to Top drive for this post:
  • Civvic
(18-12-2016, 10:40 AM)Top drive Wrote:  the 1.9 is prone to jerkyness and lacking more so in power when the MAF is not working right.
Right now, I'm quite far from Peugeot planet, but in the course of this week, I should get a mech with one to have a look at it, but unless I get another harness, it'll be one diagnosis after another. I can try cleaning the MAF & EGR with carb choke cleaner and then try to squeeze in the plug but that's as much I can try from where I am.
just curious. While you had the jerkiness issue, did your engine also manifest oil consumption? I'm trying to eliminate the cause of the oil consumption - that if it isnt related to the jerkiness.
Today 11:13 AM
Today 09:14 AM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
