  • 19 Vote(s) - 2.84 Average
Saxo Alloys
Been offered a set of Citroen Saxo VTR 14" alloy wheels at the right price.
Guy says they will fit a Berlingo.
Will they?Confusedcratch:
Know it is tight, especially under rear wheel arch. They are fitted with 185 tyres. (Mine are 175.)
Would I need spacers? (Not a fan of spacers.)
Any comments gratefully received.:thumbsup:
Any offset markings on them?
If they go on the back, the front will be fine
Not seen the wheels yet, so not sure?
If you have the opportunity, probably best to try one on for size.
If they don't fit then factor in spacers and extended bolts to your price/negotiations.
  • j90xxx
Will try and get one to try.
And messing about and will leave it...
(17-10-2011, 08:14 PM)Coco Wrote:  Any offset markings on them?
not exactly true, i have 17" alloys on mine and it was hitting off the shock before i put low profiles on. I have 195 alloys on and needed 20mm spacers and tbh i need to purchase 25mm for the back
That's when you increase the circumference, in this case it would either be keeping it the same or decreasing, hence no issue with the front suspension.
The problems you have are twofold, increasing the diameter beyond design limit and obviously the offset is not correct otherwise you wouldn't need spacers
And 1" is a BIG spacer!!!
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
