Seat belt pre tensioners
Hello I have a 2013 Berlingo enterprise van but it was crashed into the rear of, it was written off cat D.
I bought the van back from insurers to fix myself, I have fixed all the back end just have a seatbelt problem now.does anybody know if I have to change all pre tensioners or only the drivers which was in use at the time? Any help would be much appreciated thanks
As far as i am aware only if they have gone off - should be able to identify by looking at it from ones i have seen but not on Citroens.
You do not need to change them for the MOT unless regs have changed.
(17-12-2016, 07:45 PM) pid=\95196' Wrote:As far as i am aware only if they have gone off - should be able to identify by looking at it from ones i have seen but not on Citroens.
Thanks would the passenger 2 of went off even if they were not plugged in?
If they were not plugged in i cant see how they can go off. The last one i say was on a Vauxhall and it clearly stated discharged on the side.
  • david273d
(17-12-2016, 07:45 PM)polar Wrote:  You do not need to change them for the MOT unless regs have changed.
You would if it was causing the airbag light to stay on
Correct
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
