2006 berlingo multispace 1.6 hdi, has anyone changed a crankshaft sensor? if so how did you get at it? underneath? from top?what parts did take off? its on top of the gearbox. Any help,advice or comment would be welcome thanks.
Mine>>>>2006 Citroen Berlingo Multispace Forte 1.6HDI
(19-12-2016, 09:51 AM)jj9 Wrote: The Crankshaft sensor is fitted behind the Crankshaft pulley on the 1.6HDI engine.
Thanks jj9, but in the book post 2002 models it's on top of the transmission, on mine I can see the can see the wire and the plug and using a mirror see the sensor, just need better access to change it
On my 2006 Hdi 1.6 there is a crank sensor adjacent to the crankshaft pulley - I removed / refitted it when doing the timing belt a few months back so can say it is there with confidence ...............................
Serieal Berlingo owner
The following 1 user says Thank You to geoff for this post:1 user says Thank You to geoff for this post • citdingo
