Hello everybody,
Who knows the difference between Berlingo and Picasso rear rear?
The Berlingo rear axle can be used on Picasso or not? What is the difference in detail?
If you can show me the images of the difference that will be great.
Thank you in advance.
I also have 5 questions below pictures.
I hope that you will help me answer these questions because it answers very important to me. Thank you ver
y much.
1, I found a part (in the picture) with different Picasso and partner, so I want to know how they can be used to Picasso and without any partner problems or not?
2, Can you tell me Picasso and Partner length "A" (2) in the figure (length should be no shock to fix it)
3, for parts in the picture, Picasso has the same part of the partner or not?
4 Picasso has a drum brake and disc brake model. both drum and disc brakes Picasso with the same parts as shown below?
5, the lower part of the same thing or not for drum brake and disc brakes Picasso?
