Thanks Given: 3
I just had the egr valve replaced as it was fully clogged and the car was loosing power.
Since it was replaced the car is driving fine but when it's idling over there is jump in the engine, this issue is more prevalent when the engine is cold, there is also a feeling of split second loss of power when driving.
What should I be looking at now?
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
20-12-2016, 07:18 AM
(This post was last modified: 20-12-2016, 07:19 AM by brajomobil.)
What engine? Blingo year?
Check MAF sensor. Clean it with carb cleaner.
Find tutorial on youtube. Don't clean with brush!
Best regards,
brajomobil
Threads: 29
Thanks Given: 67
20
(20-12-2016, 07:18 AM)brajomobil Wrote: What engine? Blingo year?
Best regards,
brajomobil
Only method I have found with MAF sensor is to throw the old one in the bin and replace with a new one. It will run better with the sensor disconnected if you want to try it to make sure it is that. It didn't show any engine fault on our car either.
Threads: 23
Thanks Given: 46
5
As your problems started when the egr was replaced I would start with that. Check all connections and that all is tight.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• RodgerD
Thanks Given: 3
Thank you, it's running smoother now with some engine cleaner and few long runs but it's still there occasionally. The car is a 2008
I'll look into MAF
Threads: 9
Thanks Given: 316
15
Okay Rodger we are getting there its a 2008 so im guessing its a 1.6hdi?
How many miles has it got on it?
