Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 3
Hello!
You mean bulb is just stucked,or whole setting of electromotor for headlight?
Threads: 7
Thanks Received: 3 in 3 posts
Thanks Given: 4
Thanks Matija,
I think it's the whole electromotor assembly as it has happened suddenly,
Threads: 5
Thanks Given: 3
In that case,if you ask me,they are 2 possibilities,either replace electromotor,or check if its really bad,or just wiring etc.,
or disconnect wires from el.motor,adjust lamp like other one,and drive like that,this is cheapest option i think..
Anyway,i am driving car and bikes long time ago,and i never have used adjustment for lamp,always was adjusted from
factory,and it was always just fine.
Threads: 7
Thanks Given: 4
23-12-2016, 03:10 PM
(This post was last modified: 23-12-2016, 03:13 PM by JT1.)
Thanks again Matija, the wiring seems fine so suspect it is the motor, however will check connections with a volt meter and then decide what to do. May go down the manual route as you suggest.
I was wondering if anyone had had a similar experience and if so what the outcome was.
Threads: 5
Thanks Given: 3
Hi there!
Yes,if you can check like on original wiring,this would be great,and like original procedure you can fix the problem.
I have also problem on mine berlingo with burning fuse,but thanks to member brajomobil,i have found one wire which is
causing problem,now i only need to find out where it goes,but i think that probably i will leave it,because other things are working.
Cheers!
