After market radio install 58 plate XTR
Hi guys just after a bit of advice if I may.
I ordered a cheap no frill head unit to get me by until I can afford a fancy touch screen.. issue I am having is I'm not sure what loom to get for the connection at the back of the new head unit, here are a few photos to hopefully help in finding out what loom I need ( at this moment in time I'm not fussed for steering wheel controls )
[Image: 19db2886c181f14467686372681b6953.jpg][Image: 8c9f3fbe4162ba9a043adfcff72422a3.jpg][Image: 099b07ef007ff9102d73bbe10285111d.jpg][Image: 85b9b8db67f4b09326df9a4c6da1a7c7.jpg]
Sent from my SM-N910F using Tapatalk
Using Tapatalk
You need either an ISO plug set (mk2 lingo) or a quad lock set (mk3), and then splice the looms together, as it's a cheap set you won't get a straight plug in wiring loom
[-] The following 1 user says Thank You to dumdum for this post:
  • Sootyfoot
Thanks for the reply, I stumbled upon a guy on ebay that sells the connectors I need. I will attach a pic so if anybody else buys a cheepo it will help... oh and merry Christmas
Using Tapatalk
[Image: 337045f4026aba5c8cdfd8b15c1b9f9e.jpg]
Using Tapatalk
Just to add.
The central info display uses the radio head unit to interact with the outside world. I replaced mine with a double din touch screen and then found there was no way of changing the clock and things like that.
In the end I upgraded the speakers and at the same time the audio specialists tried different connectors to the steering wheel controls. They got it working, so now I can set the clock using different combinations of button presses on the steering column controls. Thought I could deal with the clock and other info being constantly wrong but it got me down after a while
[-] The following 1 user says Thank You to Lukemedia for this post:
  • WATTYUK
KPH display
Last Post: Eamon Devlin
Today 01:49 PM
UK residents take note!
Today 12:47 PM
Hello guys.
Today 10:04 AM
Touchscreen update
11-07-2025 01:41 PM
10-07-2025 10:09 PM
Adding aircon oil after component replacement
Last Post: Ian_99
10-07-2025 08:10 PM
Spare key programming ?
10-07-2025 02:37 PM
Rear electric window regulators
Last Post: phydaux
09-07-2025 10:27 PM
Problem Passenger Electic Window
Last Post: pavb2
09-07-2025 06:49 PM
Solenoide, Wastegate
Last Post: BerlingoCitroen2011
09-07-2025 06:44 PM
