Threads: 17
Thanks Received: 6 in 6 posts
Thanks Given: 64
The clutch has just gone on my 2004 2.0 hdi Berlingo van - can anyone confirm if this model has dual mass flywheel or is it solid ?
Any info much appreciated .
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
From what I can see I believe they all had a normal clutch, No DMF.
Use the link below and put your VIN in the search box at the top and you will get the details for your vehicle up.
https://www.catcar.info/citroen/?lang=en&l=
• Andre
Threads: 67
Thanks Given: 238
50
......... Solid .............
Serieal Berlingo owner
Threads: 17
Thanks Given: 64
Many thanks for the info - should be a fairly cheap fix then .
