  • 9 Vote(s) - 2.78 Average
Unusual cutting out problem
Sad
Hi all, new to this site so any help or advice is appriciated. I have a 2006 2.0 H.D.I and today it started to cut out for no reason. No coughing, no spluttering, just conked straight out while i was driving. I've noticed it will drive in reverse but once it's put into 1st or 2nd gear and you try and take off it just dies! I had to drive through a flood on the road today but i didnt think it was that deep! it will start and idle but takes a bit to start it.plz help
many thanks
That's why Noah didn't use a Berlingo!
I'M Irish.. when i say flood i mean puddle, not a lake..smartarse
[-] The following 1 user says Thank You to jockbyrne for this post:
  • j90xxx
(17-10-2011, 09:22 PM)jockbyrne Wrote:  I'M Irish.. when i say flood i mean puddle, not a lake..smartarse
Well, when you say flood, we think you mean flood, if you meant puddle you should have put 'puddle'
Just how big was this puddle? If water went into the intake it could have bent the conrods with hydraulic compression.
It was after a spell of heavy rain, it was on a country road so it did stretch from one side of the road to the other, but i thought it to be only 2-3 inches deep at most. My friend has petrol fiesta and drove straight through before me, and he hasn't had any problems with his car at all. It took a lot to start it this morning but now that it has warmed up it's idling and turning on/off no problem. Could the heater plugs be damp??
Don't think it's likely to be the heater plugs, they only come on when the weather is really cold.
I would be checking the air filter just in case it got a soaking.
You can run the car for a short while with no air filter with a minimal risk of damage, if the car runs normally without the filter in place
(or with a new filter fitted) then the old filter was damaged by the water ingress.
  • jockbyrne
Solved Guys..Crankshaft sensor failed!
[-] The following 3 users say Thank You to jockbyrne for this post:
  • brodfather11, RJBingham, RolyG
Confusedcratch: Was it flooded , if so it took along time to dry out (2 years ?):whistle::whistle:
  • ron
Probably had to hire a deep sea diver to diagnose it.Confusedcratch::whistle:
Yesterday 06:15 PM
removing front strut
Yesterday 06:10 PM
Strut Top Mounts
Yesterday 05:47 PM
Rear seat belt breakage
Last Post: Mad one
12-09-2026 06:09 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
