Threads: 29
Thanks Received: 14 in 13 posts
Thanks Given: 4
The only place I can find this info is on a 3rd party oils site, Comma I think.
2009 1.6HDI 75 B9
The site states 3.75L + 0.25L for the filter, I take it you add these together to get 4L? Thats what I've put in (assuming there was actually 5 litres in the bottle to begin with). Cant seem to get a reliable reading off the dipstick, it gets covered in oil when it goes down the tube.
Threads: 9
Thanks Given: 316
15
Leave it overnight and check in the morning if you can. 4L is not far away - if i leave mine draining for quite a while i can just get 4.2L so you are not far away.
• ron
Threads: 27
Thanks Given: 20
13
Try to fill a bit short of max on the stick, they don't like being filled right up.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
The engine generally takes a bit more than that, 4.3 from experience is about right
Threads: 10
Thanks Received: 67 in 51 posts
Thanks Given: 20
11
I had a 2010 1.6 HDi L2 and never put more than 3 litres in at any oil change. The owners book said put 3.85 litres in, which would have overfilled it! I put 3 litres into my current 2015 B9 L2 now at every oilchange.
Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 3
It goes 3,8 liters in engine,also Autodata writes that,so i would go with this. Run engine that the oil is really hot,and then drain it,leave it to drain about 1 hour,be careful so you dont get burned.
Somebody was also writing here on forum about oil change,then turbo failures,its worth to look for it,and be better prepared for maintenance jobs.
