Power flex lower engine mount bush
hi all
I am in australia at the moment and i have just purchased a 2005 berlingo however it needs the rear drivers side lower engine bush replaced. Can anyone tell me if the power flex one will fit? what is the diameter of the standard one? how hard are they to get in from under the van?
best regards
https://www.powerflex.co.uk/road-series/...h/247.html
That should fit as the outer diameter is 70mm and they seem to be the same mounting across the Peugeot, Citroen family, all engines.
And hi back at ya
I'd double check as the Powerflex website doesn't list 2005 models, contact them maybe ??
Or look here for information and cross reference, I find it a very good site .. http://www.febi-parts.com/?lang=GB
I haven't really checked the powerflex ones but tell me it's not going to be this crap
https://www.youtube.com/watch?v=f_hfyCQY9Mk
They are literally just filling up the oem bush instead of replacing it. You can do the same for fraction of the price or the ultimate solution is to weld it shut. It will make the shifting feel very positive and give you more feedback from the power train when you feather the throttle or make sudden changes. Say good bye to misshifting gears. Definitely something on my list. You got to do it all around though.
Here is what the OEM bush looks like underneath http://i.imgur.com/DZkmpSg.jpg
[-] The following 1 user says Thank You to Kokain for this post:
  • Jed Clampit
Great youtube vid love it.  Cool
got a reply from power flex and they said this was the one for my year (PFF50-420) so hopefully its ok as long as it passes the roadworthy I'm happy, i only have the vehicle for 5mths
many thanks
(03-01-2017, 11:21 PM)charllieuk Wrote:  ........ as long as it passes the roadworthy I'm happy ......
Paint it black so it doesn't attract attention ..................
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
