[Brakes] Brake Fluid
Got new drums and shoes to put on my 2006 Van, also got a wheel cylinder "just in case". Just need to clarify if any Dot4 brake fluid is compatible with the original fluid. The owners manual mentions using synthetic fluid ( Citroen specific) but as all brake fluid is technically synthetic am I finding a problem when there isn't one? Was going to be using Pagid Dot 4 fluid from Eurocarparts.
Dave.
That or any other DOT 4 will be fine.
  • tanto
Shocked
(03-01-2017, 09:25 PM)Lighty Wrote:  That or any other DOT 4 will be fine.
Thanks Lighty,
that's what I was thinking but just wanted to make sure
I change the brake fluid every four years even when I change cars and if its a Citroen or a VW the dealer does it for 49 Euro and i think the same offer is available in the UK
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
