[Transmission] 2012 Multispace clutch
Hi FOlks
I've posted before about the bite point on my clutch being around 1/2" from floor. Out this morning going up thro the box and it refused to come out of 2nd till I depressed clutch again.Operated thro all gears normally after that.
THen when parking, reverse was a bit crunchy ! Its like the clutch is not fully releasing ???
Any thoughts?
Thanks !
Ger
It sounds like the hydraulic system needs bleeding/fluid change.Do that 1st as the simplest option & see how it goes.Good luck.
Unless you have a cable clutch like mine and the cable is sticking, or the auto adjust isn't working correctly. I had the same issue with my Berlingo when I first bought it. I lubed it with GT85 and reset the auto adjust and it has been fine since. I will lube it again with AC90 when it stops raining and check it all over again. What Berlingo do you have?
had a look at the combined clutch/brake fluid reservoir and there is no fluid loss........Booked it in to garage on Thursday for them to have a look......
Well, an update on this.....
The old skool owner of the Garage I use had a drive around and felt a roughness/vibe that I had not noticed. So it went in and they dropped off the gearbox. This apparently was a cnut of a job that he would not like to repeat.....!
This revealed that its probably had a clutch in the past and the pressure plate was not correctly attached and was in fact sitting loose, bad enough to have bent the fingers on the pressure plate.
A new clutch kit was fitted. All in all it was not an inexpensive exercise  Dodgy Dodgy
Pleased to read that you have it sorted.
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
