[Engine] Failing to start after new battery fitment
Happy new year and good health to everyone,  Can anyone help with a problem I have with starting, after fitting a new battery to my 2004 B59 Berlingo, It fired up then stopped, now it just spins over making no attempt to start, the engine management light stays on, I fitted new glowplugs  in 2016, I have seen on this forum a mention of resetting the B.S.I., what is this and how do I do it, could there be any thing else?  Thanks guys (and Gals) for any help.
I cannot see what Berlingo you have but post#4 in this thread should help you.
http://www.berlingoforum.co.uk/Thread-Re...t#pid61783
[-] The following 1 user says Thank You to Trevor for this post:
  • hunnsy
(10-01-2017, 03:05 PM)Trevor Wrote:  I cannot see what Berlingo you have but post#4 in this thread should help you.
Thanks Trevor, I will go out into the freezing garage now and try it, (by the way its a 1.9 multispace), I was fearing the cam belt had snapped by the way it is just spinning over, hope its not, but will gingerly check also!
Just an update, the thread Trevor directed me to, worked after 3rd attempt, once the engine management light cleared, away it went, thats a new heavy duty starter, glow plugs, fuel filter, and now a new battery, hope she now behaves better in this cold weather!. Thanks again Trevor, you are a star.
Pleased to read that you got it going ok. Thanks should go to the original poster of the instructions years ago.
Today 11:26 AM
Drop in fuel economy
Today 09:38 AM
rear washer fires front?
11-01-2025 05:03 PM
knocking from rear
11-01-2025 04:51 PM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
Frequent DPF REGEN's
11-01-2025 08:59 AM
Last Post: Andhall
10-01-2025 08:31 PM
How to change your username
Last Post: Blakey
10-01-2025 08:06 PM
Carplay to android auto
10-01-2025 07:55 PM
Key fob
Last Post: Squad
08-01-2025 10:36 PM
