15-01-2017, 09:47 AM
Hello All,
You've given me great advice in the past which has been much appreciated.
We have a 2005 2.0 HDi multispace which has recently had the clutch replaced..
Since the clutch has been replaced it doesn't go into 3rd gear properly.
You can put it into third and drive OK for a while. Then when you put the clutch down to change up to 4th it jumps out of 3rd into neutral..
It also jumps out when in 3rd and going up a hill when you take your foot of the power when going around a corner and then put your foot down again...
The garage say they think the fault is in the gearbox, but it never did this before the clutch was replaced...
Any ideas on what might be the problem are gratefully received.
Sasha
Sasha
