Are Mud Flaps the Answer ?
The tail gate of my 2012 keeps getting covered with dirt and mud  its worse when there is just damp on the road, I have to keep using the rear washer to clean it ( every few minutes)  so would mud flaps be the answer? As anyone had the same problem and did it stop when mud laps  fitted?
I don't have the problem with my 2007 but it does have Flaps but  is not the same shape as the 2012
I had factory mudflaps on my 2008 MkIII Multispace, it stops the roostertails of water from the rear wheels due to the short rear overhang from the wheels but it didn't stop the rear getting filthy, thats more due to the vertical rear of the car.
It never really bothered me to be honest as I drove vans for many years without rear windows.
As others have said they will help, in reality best to have them anyway. The vertical back end causes a vacuum, you can blame aerodynamics for that one, anyway it actually sucks the crap onto the rear of any vertical rear vehicle to various degrees.
Side mirrors are your friend.
Having looked at the rear wheel arch there does not look like there is any drilled holes to attached mud flaps other than the edge rim of the wheel arch where I would have to drill.
In the mean time Iv'e ordered a power washer from Amazon so I can give a quick wash before it gets too dirty and  just used the last of screen wash  never used so much screen wash with this car  Sad
Mine has the rear spoiler and the back still gets covered in muck
(18-01-2017, 07:10 PM)iscom Wrote:  Having looked at the rear wheel arch there does not look like there is any drilled holes to attached mud flaps other than the edge rim of the wheel arch where I would have to drill.
The OE ones clamp on no holes needed
Don't drill holes. You will cause rust to start. Use clamp on versions
will still get dirty due to the low pressure area created behind the flat back causing the s**t to be sucked in .
06 pug partner van dw8 106k miles
04 citroen berlingo forte  dw8 125k miles
15 Pug Partner tepee outdoor
16 nissan nv400
87 Land rover ninety pick up
24 52kw pug e-rifter GT line
aerodynamics isnt all to do with simply with rounded vs flat back either
Height and width of the foil plays a huge part - the air has much further to travel over the top of the car than under.
This also generates an area of negative pressure behind that then draws the air under the car upwards to fill the void - under the car has all the s**t off the road in it also...
16 nissan nv400
Having to go with the idea of fitting mud flaps I started to look for some and most of the moulded shape ones look like they have to be screw on, and the clamp type are the universal type flaps (although cheaper) on looking closer at some of the photos flaps for sale, I have a feeling most,  if not all would have to be cut to enable the clamps to be fitted on the wheel arch unless I bought official flaps from a dealer which seem very expensive,
So what I thought would be an easy job may not be so easy,  so maybe I should wait till the weather improves then have a closer look to decide what is the best solution. but right now have to be careful when opening the tailgate and getting my clothes dirty even more when using the boot camp
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
