clunking noise
Can anyone shed some light on this for me please ??? ,now and again i hear a clunk noise when turning right, or reversing to the right, both at very low speed !!! been under car and everything is quite solid ???, had lower sus arms replaced, and anti roll bar linkages replaced for MOT 6 months a go, these are ok !!! also ABS light came on today, so fiddled with connectors under seat(fixed now)i noticed a small white tube hanging there,the other end going up the back rest i think (passengers seat )there isn't one on drivers seat ,does anyone know what this is for ??? Thanks Gwyn
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Clunk may be drive shaft,
Check the top mount's on the front strut's .
engine or exhaust mount and as above have said ^^
hey it could even be a spring shifting in the strut cup
Have had the same on my brothers older mk1 and it was a broken spring in the top mount but couldn't see it until put up on ramp and Jack.
(22-01-2017, 03:39 PM)my mucker Wrote:  also ABS light came on today, so fiddled with connectors under seat(fixed now)i noticed a small white tube hanging there,the other end going up the back rest i think (passengers seat )there isn't one on drivers seat ,does anyone know what this is for ???  Thanks  Gwyn
The connector under the seat would be nothing to do with your ABS light more to do with airbags. Does your seat have lumbar support adjustment, has someone fitted a different seat ?
sorry Ffrenchy airbags i meant to type !! doh !! right i got you about lumber support,so it would be pumped up using the tube with some sort of hand pump attached to tube,ok i can live without that, thanks. Ffrenchy . Johny 555, Jed Clampit and Polar thank you all very much for your input, very much appreciated indeed, is this something that has to be seen to A S A P !!!
I would get it looked at soon,
ok will do , thanks all very much indeed
Mine was clunking too which as Silverberlingo said turned out to be a broken spring right at the top. (Spotted it once it was on a jack).
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
