Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
The bleed valve is on the slave cylinder located at the front of the gearbox.
• paraman
Threads: 16
Thanks Given: 46
5
Fluid should be replaced every 2 years.
Threads: 83
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
is there any reason this cannot be done with a pressurising type brake bleeder?
I'm thinking of getting one and it would be added value towards the expense.
Thanks Received: 69 in 64 posts
Thanks Given: 2
11
Pressure\vacuum bleeders are very handy. Generally worth the money.
The only snag on the berlingo is that the bleed screw isn't at the highest point of the slave cylinder, so if you get air in the system be ready for a bettle. One tip I've seen suggests unclipping it and turning it slightly to get the screw uppermost.
The following 1 user says Thank You to shtu for this post:1 user says Thank You to shtu for this post
• evdama
Threads: 83
Thanks Given: 179
21
(02-12-2024, 09:19 PM)shtu Wrote: Pressure\vacuum bleeders are very handy. Generally worth the money.
Thanks shtu
