[Engine] wont start berlingo 2002
hi everyone . my van was going ok then . start get hard to start . now no glow plug light on when you switch on . and sounds like a immoblilser not turn off. but not no if it has a immobilser as my last berlingo had a chip in key this one does not never had 1 .
and when it gets to just above red on fuel guge it cuts out then start . help please .
Check the plugs are working 1st.I believe the fuel pickup in the tank can give problems when run too low.I never go below 1/4 full.
[-] The following 2 users say Thank You to ron for this post:
  • wfp1, whitebus
(28-01-2017, 04:27 PM)ron Wrote:  Check the plugs are working 1st.I believe the fuel pickup in the tank can give problems when run too low.I never go below 1/4 full.
Hi Ron how can I check glow plugs . Many thanks peter
Hi Peter, there is a Haynes Manual on this site for download have a search for it and get a copy as it will help you enormously !
Glow plugs testing, essentially two methods.
1/ Disconnect the wiring and use a multimeter to check resistance / continuity on each plug
2/ Remove each plug and check each for ability to glow bright red / almost white hot
Google is your friend for learning plus there are many instruction videos on YouTube
  • whitebus
Cheers Geoff . I'm not even get glow plug light on dash
(30-01-2017, 03:12 PM)wfp1 Wrote:  Cheers Geoff . I'm not even get glow plug light on dash
That could be the bulb or relay.You'll need to test the circuits.
Ok cheers
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
