Third Gear Crunching
Currently got a 54 plate 2.0 HDi with 100k miles on, shes crunching/grinding third gear, is there anything to try before I fit a replacement gearbox? Also the engine seems to knock when starting up so maybe an engine mount gone not sure if this would cause the crunching? Also the clutch is heavy but from what ive read it seems that's how a berlingo is in general?
Mark
(28-01-2017, 03:47 PM)Markt8 Wrote:  Currently got a 54 plate 2.0 HDi with 100k miles on, shes crunching/grinding third gear, is there anything to try before I fit a replacement gearbox? Also the engine seems to knock when starting up so maybe an engine mount gone not sure if this would cause the crunching? Also the clutch is heavy but from what ive read it seems that's how a berlingo is in general?
Mark
Check the mounts 1st as the linkage may be fouling.Do it ASAP before it becomes permanent.The boxes are usually very strong.
The usual gear to fail is 3rd, the sincro goes so hence the crunch. No need to change the box yet just get your revs and road speed right and 3rd will go in without a crunch.
(28-01-2017, 09:54 PM)polar Wrote:  The usual gear to fail is 3rd, the sincro goes so hence the crunch. No need to change the box yet just get your revs and road speed right and 3rd will go in without a crunch.
Anyone had the syncro done and know the cost of the repair???
sliding door panel removal
Last Post: mojito
Yesterday 07:35 PM
XL tyres
Yesterday 06:57 PM
Last Post: deejay_xb
Yesterday 10:06 AM
» Replies: 32
Unusual Braking Problem
Yesterday 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
Rumbling Noise 55-65mph
22-03-2025 09:47 PM
Last Post: Beaumotor
21-03-2025 04:38 PM
