Fuel one way valve
I park my berlingo 1.9d on a down hill slope and it.starts but if i park it uphill the fuel runs back to the tank. Id likr to fit a oneway valve to the fuel line somewhere. Has anyone done this? Thanks.
if your fuels running back to the tank then you have an air leak into the system
change the fuel leak offs on the injectors , check the injector seals. check all the unions and check the fuel pipes. If the system isnt leaking air it cant run back
a one way valve is a sticky plaster , some monkey did this on an old car of mine instead of changing the leak offs and i ended up the air leak turning into a fuel leak with an engine covered in diesel smoke in the engine bay from where it was dripping on the hot exhaust.
06 pug partner van dw8 106k miles
04 citroen berlingo forte  dw8 125k miles
15 Pug Partner tepee outdoor
05 iveco daily LWB campervan
87 Land rover ninety pick up
16 1.2 Pug 108 GTline
electric long tail cargo bike.
How do you change the leak offs. The manifold is in the way
Engine Fan Running
Yesterday 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
