Threads: 4
Just bought a 2.0 hdi berlingo it has a problem where it jumps out of 3rd and 5th there is no crunch or anything and the gearbox doesn't wine. Could this be a worn engine mount or. Gearbox mount?
Thanks in advance
Sent from my ONEPLUS A3003 using Tapatalk
Thanks Given: 188
23
Hi there welcome to the forum, does the gear linkage feel loose and sloppy its probably the rose joint linkage underneath. Worth checking first before you start looking at gearbox and clutch. There are plenty of threads on here with diagrams so you know what your looking at and there is also a workshop manual you can download to help. Have a search you will come across them and give you many hours of reading.
Are we there yet?????
Threads: 9
Thanks Given: 316
15
If its not the linkage its the nut on the end of 5th gear come loose.
Threads: 4
The gear linkage isn't sloppy at all only reason i thought it might be engine mount is the gear stick moves quite a lot when accelerating also engine shudders when its turned off. How do i check the nut on fifth gear. Box out?
Threads: 9
Thanks Given: 316
15
No you remove the end plate on the gearbox you can do it with the box in from under ns wheel arch
Threads: 4
Take it i need to drain the box oil first?
Threads: 4
Its a 2003 with 137000. I cant find any threads about it. If you cab point me in the right direction would be appreciated
