Threads: 5
Thanks Received: 1 in 1 posts
Van is new to me, it whole van leans to one side ....any ideas, drives fine but over speed humps it seems the rear is lazynon one side
Cheers
Threads: 9
Thanks Given: 316
15
Wow thats a blast from the past "NSR500"
Anyway check the front coil springs first - the coils can break and are sometimes not that easy to spot.
Then go for rear shockers - disconnect and try in the zone the work in most of the time. If all that is okay then go for the rear torsion bars - you may have a broken one or lazy one. They can be adjusted but i have seen them with a lean before but its very rare.
• Angela
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
Rossi you Italian? My partners Italian that's her last name,or do you like valitno rossi the bike racer,,check yo rear axle are the wheels going in at the top?
Threads: 29
Thanks Given: 67
20
It sounds like a torsion bar broke
When my front spring broke it made no difference to the height of the car but it made a horrible noise when you tried to steer right or left.
Threads: 5
Haha yes it's nsr500 as in the Honda nsr500 Grand Prix two stoke and Rossi as is valentino ?
Thanks for the advice ..the van is not lower on any one corner ..it's pretty even front and rear and the rear wheel is not leaning in
Not clonking or grinding noises ..drives fine ..just when going over speed bumps it seems how you say ..uneven
Threads: 20
Thanks Received: 23 in 20 posts
probably had one spring replaced due to snappage and left the saggy old one on the otherside.
06 pug partner van dw8 106k miles
04 citroen berlingo forte dw8 125k miles
15 Pug Partner tepee outdoor
16 nissan nv400
87 Land rover ninety pick up
24 52kw pug e-rifter GT line
Threads: 5
I spoke to a mechanic friend and he said the same ..one spring replaced and saggy old one Left ..makes sense ...maybe . I shall measure the distance from centre of wheel to arch at the front, if one side is higher than the other then I guess it's the spring as that would effect the rear ride height as well ..does that sound right
Cheers
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
The strength of the springs set the ride height , worn shock absorbers don't affect the ride height, just the amount of bounce in the springs.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
