Thanks Given: 2
Hi all im going to replace my serpentine belt dw8b engine is there a diagram about , it has pas no ac
also to replace the tensioner roller do you have to drop the engine down a bit as the bolt seems close to the leg
thanks tony
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
I would be drawing a diagram of the route before I take it off.
2001 1.9D Multispace.
Threads: 67
Thanks Received: 716 in 613 posts
Thanks Given: 236
50
Good call Mal and for those who are a part of the modern age perhaps take a photograph on the phone ...
I still use paper and pencil .........................
Serieal Berlingo owner
Thanks Given: 2
any ideas on the tensioner roller
Threads: 67
Thanks Given: 236
50
Tensioner - I've never needed to drop the engine but it can be fiddly with fat fingers.
Threads: 67
Thanks Given: 236
50
Memory fails me on exact details sorry it has been a while now .... don't want to give a bum steer.
Anyway engine up / down is quick and easy when you remove the top mount and casting, no need to remove any other mounts down below even for timing belt.
Threads: 19
Thanks Received: 23 in 20 posts
Poke that
Aviation spanner (long flat ring spanner)
Easy job.
06 pug partner van dw8 106k miles
04 citroen berlingo forte dw8 125k miles
15 Pug Partner tepee outdoor
05 iveco daily LWB campervan
87 Land rover ninety pick up
16 1.2 Pug 108 GTline
electric long tail cargo bike.
