Threads: 23
Thanks Received: 27 in 24 posts
Thanks Given: 31
4
Anyone recommend one for a B9?
I did search the forum but the only results were for the older models, Do they still work with the B9?
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Diagbox with the interface cable.
2001 1.9D Multispace.
Threads: 52
Thanks Given: 87
5
Or an app like Torque on smart phone connected via bluetooth dongle.
Threads: 12
Thanks Given: 16
37
A fault code reader is a generic device, that reads the Eobd data that has to be available from all cars after a certain date. You can use one on a Bugatti Veyron of a Ferrari.
This information is purely emission related, and will not necessarily enable you to find out specific engine faults, or other issues with the car.
For example, Renault are good at hiding their information away from eobd readers & even some fairly sophisticated garage diagnostic software.
Nothing will ever be as good as the manufacturers equipment, because it was specific for each model they make.
To successfully diagnose a B9 Berlingo, you must use Diagbox, even Lexia is not up to the job as it is too old.
However a simple Eobd reader will often get the basic engine codes from an ecu, which with the help of google will be an aid to repair.
The following 2 users say Thank You to Lighty for this post:2 users say Thank You to Lighty for this post
• Hughzie, polar
