Threads: 21
Thanks Received: 4 in 4 posts
Thanks Given: 16
Aside of a loud screaming noise from the engine bay my 2010, the car also had a judder when it car pulls away from low revs, when in traffic for instance. The car went in for a new clutch and a 3 part kit was fitted. When I picked up the car the judder was worse so they fitted a complete new clutch. I picked up the car and found the judder was still there albeit not as bad as it was originally. I had this issue on a Fiat Doblo and cured it by replacing the dual mass flywheel.
My question, does the 1.6 have a dual mass flywheel and could the judder be the flywheel?
2010 Berlingo Multispace 1.6HDi - Chipped
Threads: 20
Thanks Given: 2,126
18
I didn't thing that any Berlingo had a DMF?
Strawberry flavoured windows
Threads: 21
Thanks Given: 16
Actually, my 1.6hdi does NOT have a DMF. My judder must be something else.
Threads: 13
Thanks Received: 29 in 24 posts
Thanks Given: 1
l have the same problem, the change to normal clutch is near. I m going serch kit to remplace DMF.
Vigo, The cradle of all Berlingos / Partners.
Threads: 21
Thanks Given: 16
(28-02-2017, 05:46 PM)ron Wrote: (28-02-2017, 02:30 PM)old son Wrote: Actually, my 1.6hdi does NOT have a DMF. My judder must be something else.
That's interesting.What year is yours?Have you checked the obvious like en
g mounts,wishbone bushes etc?
That's my next step. It only happens when revs are low, moving forward slowly in traffic or pulling away uphill.
Threads: 21
Thanks Given: 16
Took the car back and they have fitted a third clutch!! Juddering better but its not completely gone. My sons 51 plate Punto has a much smoother clutch!! Not impressed.
