Threads: 9
Thanks Received: 13 in 8 posts
Thanks Given: 3
Doing some more serious sound isolation upgrade to my '15 Berlingo Multispace. After I did the rear door sound isolation it gained some weight and now doesn't open so easily and it slams too hard when closing.
I assume I just need more powerful gas struts to compensate a bit more door weight, anyone knows where to get those?
I see the original struts are around 167 Newtonmeters of force if I read what's written on the strut, anyone know around 200Nm struts that fit Berlingo?
Thanks in advance!
Threads: 9
Thanks Given: 3
Cheers mate,
will definitely look them up.
Threads: 28
Thanks Received: 372 in 326 posts
Thanks Given: 63
19
Wait till the weather warms up and the gas expands. They have a minimum and maximum force rating.
RS components in UK sell them do you have anywhere similar.
Threads: 9
Thanks Given: 3
Not sure it changes much since when I heat up the car it doesn't change much. Must wait till the summer I guess...
Here we have 6 months of cold weather so I guess I got to install stronger struts, will check the RS Components as well - thanks for the recommendation!
Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 10
http://www.sgs-engineering.com/gas-struts
Bought enginr stand off these, and they do gas struts.
Malcolm.
2001 1.9D Multispace.
Threads: 49
Thanks Received: 81 in 75 posts
Thanks Given: 141
7
I think you'll find it difficult to get a good compromise of strut stiffness for your purpose. Even though stiffer ones will better support the open door they wont do much to improve the slamming because they don't have much control of the door at that point in the travel. My standard weight rear door shuts acceptably if all other doors and windows are shut but slams noisily if any are open. Thinking about it, a possible way to improve the slamming might be to add more/more progressive bump stops
Matt
2019 Multispace BlueHDi 100 Flair Nimbus Grey Met
