Threads: 8
Thanks Received: 2 in 2 posts
just wondering what could be issue on my clutch, its heavy as hell, squeeky and is on the verge of making my kneecap implode, i read the search index and have a few ideas but my symptoms are-
full range of motion and no play, really heavy to press and squeeky with it.
I drive a mk2 berlingo van and the clutch is light as a feather and have driven allsorts over the years and never had a clutch this heavy so it cant be just the (norm)!
I dont wanna have to fork out for a new clutch, could it be the cable? the pressure plate wearing down? any ideas before i trad it in for a lovely van instead!:S
Threads: 20
Thanks Given: 2,126
18
You drive a mk2 with a light clutch,so what vehicle has the problem?
Strawberry flavoured windows
Threads: 8
? title says heavy clutch? thats the problem, my works mk2 van is light and fab, my mk2 multispace is heavy and crappy!
Threads: 41
Thanks Received: 30 in 27 posts
Thanks Given: 16
Mine is the same, and getting worse - my thigh is like Popeye´s forearm!!! Local Citroen specialists said it was the clutch itself and would need to be replaced. Mine has also started to judder a little when setting off too.
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
"....my works mk2 van is light and fab, my mk2 multispace is heavy and crappy!...."
Are they both the same engines??
Thanks Received: 5 in 4 posts
Had heavy clutch on my multispace, changed at 70,000 after a life of towing, now nice and light.
Threads: 8
my vans a 1.9 diesel and really pokey, the 1.6 feels so heavy in comparison and the 1.6 petrol engine feels quite slow to me, its ok i spose from the lights but 50 to 70 seems to take ages with my foot flat to the floor.
Threads: 20
Thanks Given: 2,126
18
When was it last serviced? What MPG? It could be as simple as a dirty air filter/fuel filter.Check the easy bits first,it helps to keep the bills down.Good luck,let us know how you get on.
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
(21-10-2011, 07:18 PM)DEZZIE Wrote: my vans a 1.9 diesel and really pokey, the 1.6 feels so heavy in comparison and the 1.6 petrol engine feels quite slow to me, its ok i spose from the lights but 50 to 70 seems to take ages with my foot flat to the floor.
The 1.6 petrol has hardly any torque, especially compared to your diesel, and I find needs to be revved quite hard to get it to shift. Mine also has a stiff clutch which I think is more to do with the cable than the clutch mechanism.
