My car doesnt start after changuing battery
Today I changed the battery of my berlingo 2007 but now it doesnt start at all, someone told me that it could be that it got locked but I dont know, please help
Sent from my Nexus 6P using Tapatalk
Hola pepinorios and welcome. When you say it doesn't start could you be more specific? Do you mean it doesn't turn over at all or the engine turns over but doesn't fire. Try a BSI reset. You'll fine the procedure on the here on the forum.
It doesnt turn over at all, it happened exactly after i placed the other battery
I tried the bsi reset but is the same Sad
Is the replacement battery good? Check connections to battery, earth, starter. Can the car be jump started?
Hello and welcome
Does the battery have the connectors in the same place ie the positive and negative terminals in the same position
Have the new battery tested
Charge up the old battery and put it back on
Borrow another battery
If is placed downhill it does start and the battery replacement was done good
(08-02-2017, 07:49 AM)geoff Wrote:  Hello and welcome
I placed the old battery but is the same, I dont know if I made the bsi reset well Sad
Why did you change the battery ?
Definitely try a BSI reset again as it is quick and free.
It was to charge the other one(big mistake) but it didnt start up so I decided to put it back and at that moment it never turned over the engine
Today 03:10 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
