Engine Code
Hi,
Where can I find the engine code for a 2012 (62) Berlingo Van, 1.6 hdi 75.
Looked round the engine bay but can't find it. Thanks
Huh 2012 (62) B9 Berlingo 1.6 Hdi (75hp)
The engine code will be in the VIN , its behind the clear panel at the bottom of the windscreen, seen from the outside .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks, Which part of the vin is the engine code ?
Chances are that it'll start 'DV6', maybe DV6FE ?
It should be the 6,7,8th no. that gives the engine code
(16-02-2017, 01:15 PM)brodfather11 Wrote:  It should be the 6,7,8th no. that gives the engine code
Top man. Got it now. Timing belt change and there are 2 different types for a 12 reg 75hp .
Sent from my SM-G920F using Tapatalk
Vin is -
B9HNOC
56789th Numbers.
So it would be a 9HN then.
So where would the DV6??? come from then.
I have seen these engine codes while looking for parts.
(16-02-2017, 03:47 PM)webcrafty Wrote:  Vin is -
B9HNOC
56789th Numbers.
Curious indeed. Did you try putting you reg number into ECP and/or GSF?
http://www.engineandgearboxes.co.uk/mode...(DV6ETED4)
I don't know if this helps?
https://en.wikipedia.org/wiki/List_of_PSA_engines
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
