Ventilation in plywood bed units
I have a single bed unit. I have seen on Youtube comments about the need for holes in the ply base to ventilate and stop dampness from body warmth getting into the bedding. I have not noticed this myself- is it a good idea and worth doing. I use a Duvalay in mine.
Yes it's a good idea. We have a trailer tent and the bed is on a slatted base and if the slats are left out there is condensation under it in the morning from body heat.
............. Yes !!!!!!!!!!!! ......................
Thanks. I will get the drill or better the Jigsaw.
(20-02-2017, 03:53 PM)lakeside Wrote:  Thanks. I will get the drill or better the Jigsaw.
Get some holesaws on the job, drill through twice then join them together with the jigsaw or a router.
reduces the weightalso which I found is a bonus
I made holes with a holesaw and then joined them up into slots with a jigsaw.
I think it depends on what you're using as a mattress. For example, an airbed made of plastic probably won't benefit from vent holes in the base, but a foam mattress probably will.
This year, I've been using a folding bed frame with springs & steel links etc on a wooden frame, with a single foam mattress on top, must say that it's been the best bed ever in a van.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
