[Engine] EGR clean, plastic separation
Hi all,
Decided to clean my EGR and have a quick question. It is a 1.6hdi (57 reg) 9HXC engine (no fap). Once I take it off, do I need to separate the two bits, the plastic (supposedly electronic part) from the bottom one in order to clean it properly? I have a carb cleaner and was thinking of soak it in that and have a toothbrush to clean it properly. If it is easy to separate them, if there some specific procedure to put them back together, some sort of alignment?
Thanks for any pointers.
(18-02-2017, 08:53 PM)saskak Wrote:  Hi all,
Hope it helps:
https://www.berlingoforum.com/Thread-Eng...case-study
https://www.berlingoforum.com/Thread-Eng...engine-ECU
Best regards,
brajomobil
[-] The following 1 user says Thank You to brajomobil for this post:
  • saskak
Hope it helps:
Best regards,
brajomobil
Many thanks indeed, that seems quite helpful.
Yesterday 10:15 PM
Not able to register
Last Post: Pricklybuzzz
Yesterday 09:02 PM
2011 B9 DPF warning light
Last Post: IKUN
Yesterday 03:30 PM
M59 rear wheel splay...
Yesterday 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
Yesterday 03:09 PM
Last Post: pondweed
Yesterday 01:21 PM
Yesterday 12:41 PM
Yesterday 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
Last Post: Matt Haigh
Yesterday 12:43 AM
User Registration Problems
Last Post: Mike
20-01-2025 10:39 PM
