Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Hiya all, I am looking at replacing the lower wishbone and it is the non removable ball joint type.. part number 3521.j3..
A silly question but there are three different types of wishbone available, does anyone know if they are interchangeable ??
Thanks..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 29
Thanks Given: 67
20
You can swap the pressed ones for the cast ones or vice versa I've seen a Multispace with one of each fitted.
Threads: 67
Thanks Received: 716 in 613 posts
Thanks Given: 236
50
Do be aware that the cast ones cost significantly more than the pressed ones.
Serieal Berlingo owner
Threads: 8
Thanks Received: 499 in 448 posts
Thanks Given: 305
33
(25-02-2017, 09:08 AM)ffrenchie Wrote: You can swap the pressed ones for the cast ones or vice versa I've seen a Multispace with one of each fitted.
I wonder why they fitted the cast version with the non removable ball joint to some models and not others?
My car has the cast version fitted, it would be good if I could change to the pressed version with replaceable ball joins when the time comes.
